its for his vibrator
its actually ProjectA, but no experience with them,
Most use either Piranha or Redarc
http://www.ebay.com.au/itm/PROJECTA-...item33871b4946
Is this the one
It is? This is their logo
http://www.nissanpatrol.com.au/forum...id=49577&stc=1
They may have changed their branding but when first on the market it was ProjectA.
but most call it Projecta. No big deal though lol Ring them lol
potatoes potartoes
The mystery button. Any ideas? Yes I've pushed it :)
The Projecta 100amp
Annd what's this for???
Trace the wires from the switch and see where they go? Maybe the battery isolator override? Hear any relays when it is switched?
I think the 2nd switch is the engine idle up switch used to warm the motor up quicker? Have you pressed that one?
This GU thing is too complicated for your old brain!
As Winnie said, the switch on the right is a fast idle switch, it is disabled as soon as you accelerate.
The switch under the fuel cap release could be for anything, usually a blank hole there.
Yeah I reckon it might be to link batteries. What Winnie said trace the wires should solve it.
Nice truck good luck with it sure it will progress nicely. Shame I never got to meet old g :(
Agree with shitbag, it's the override switch and the idle up switch:)
The idle up will disengage as soon as you put it into gear and then stop working when temp is up
Manual override(this is from their website, I'm not that cleva)
Manual override is activated by connecting the override
wire to 12V DC. This bypasses the automatic voltage sensor
allowing the relay to be engaged below the set voltages.
