I busted two silicone guns so raced into Bunnings and bought the heaviest gun they had , lasted half a tube so put a big drill bit on the handle of an old one to stiffen it up and didn't use the screw on nozzles .
Just made it .
Just made it .
Did you use the etch primer on all surfaces before gluing .
The set that I got for the van came with the sikaflex and an etch primer , the primer I'm positive was just acetone with black dye in it so you knew where you had prepped .
Never used it on the poptop roof just cleaned with metho and slapped the glue on , two years later I gave the poptop away but removed the panel , that glue is mighty strong stuff .
Just wrapping up from my sons 16th. Crap where have all those years gone.
After much hair pulling and choice words finally setup the spot trace tracker and wow , not only can I get a satellite photo I can get a map , resolution not good enough to make out a car just , but sheds houses trees there is no hiding from it .
Privacy isn't really an issue so you can still crap in the woods without the sat watching you but you can tell which house your item is hiding at or which shed its in .
Whats this spot trace tracker you speak of?
Put up a pic in what did you buy today , yesterday.
It's a small GPS locator that you put on a vehicle, camper trailer etc and is fitted with a motion detector and GPS , the second someone moves your car or whatever it sends you an alert message and gives you the exact location from a satellite image or a map and the coordinates of where it is .
There are hundreds of these things on the market but which one to get , we decided not to cheap out and bought locally but if you buy over the net you can pick one up for $100 - $150 bucks but then you need to setup an account which costs $119 us money for a years subscription.
If you give your details to your mates and family they can watch you as you travel which can be handy because you can tell how long you have been in a particular location eg broken down or bogged , sick etc .
More important if someone pinches your whatever you can call the cops give them the log in details and get them to retrieve or you can track the barstards down for a bit of bush justice .
Only downside is you need internet to get an alert or track but for me I have a sat phone and can ask my son to tell me where it is .
Attachment 71923
