I used these on the GUIV running 28PSI and never had a problem with them
https://www.uniclamp.com.au/products...29c99014&_ss=r
Been finishing off installing some gauges and bits in the top flap of center console GUIV, but out in came again to change e-locker switch... it gets easier
Hey, that's woken my brain up. How hard is it to remove the stock radio? I might be doing that soon.
Cluster all hooked up and even works. haha
Main and Aux battery V_meters w/2xUSB chg ports each.
Auber type gauges w/pyro measuring air temps in hot/cold side FM cooler.
Switch E-locker + a secondary isolator rocker around side of console.
Finished wiring in all the lights.
I think I have enough..https://www.nissanpatrol.com.au/foru...2024/06/57.jpghttps://www.nissanpatrol.com.au/foru...2024/06/58.jpghttps://www.nissanpatrol.com.au/foru...2024/06/59.jpghttps://www.nissanpatrol.com.au/foru...2024/06/60.jpghttps://www.nissanpatrol.com.au/foru...2024/06/61.jpg
Check this post out may help mate:
https://www.nissanpatrol.com.au/foru...418#post846418
New (used) non-leaking vacuum pump 110 amp altenator installed.
Also upgraded the wiring to the battery with 185 amp rated wire that has a 125amp midi fuse on the battery and one for the altenator side. Basically ripped off the idea from the Qikazz website and made it myself for a lot less with some stuff I had laying around.
Attachment 88236
Even got fancy with nutserts instead of tek screws.
Attachment 88233Attachment 88234
You can see the turbo is off while I was waiting for a turbo to dump pipe gasket from MTQ to arrive.
Attachment 88235
