Cremulator
Rossco, I would cost up the TB48 calipers, rotors and master cylinder against the hydraulic brake booster from Mark's 4WD. Personally (and this is the way I decided to approach it) I would do the hydraulic booster first, then add calipers and rotors.
The TB48 calipers will work well with the hydraulic booster if you decided to upgrade them later, but I gotta say you will be more than impressed with the difference just the hydraulic booster has on the braking response!
