more piccies, You will notice with the door that I have only done what I can. it was way too far gone and I will replace this one when I can
this is the before shot from early in the thed
Coming up a treat michelle good onya
It's starting to look like one mean truck :D
Again thanks for all the positive feed back I know now I may have made a few mistakes, but hey I will learn for next time and if I have to do a few things again after the RW check then so be it, or evan after well, gives me something to do other than chace kids around all day lol and i'm still enjoying it :D. Cheers
Michelle
So last time I was at the farm I took a lot more notice since readind some of the manual, any way found this as I looked thru the grill on the passanger side of the radeator, cut and weld or grind and weld advice please Cheers
Michelle
Grind and weld Michelle, It doesn't need totally removal. And if you haven't already, buy some chemical rust converter, once ground and welded, paint on some converter to nuetralise the rust. Ready to paint once dry.
Tim
Thanks Tim got plenty of converter going thru it by the bucket full lol :)
So thinking of heading to the farm on the weekend weather pending, might finnish off some of the smaller unfinnished body work, then pull off the rear wheels, wire brush of all the peeling paint under the wheel arches, re prime and paint under there. While I have the rims of might even clean them up and give them a fresh coat of paint too :)
Sounds good just go harder and faster so we can see more piccies ahahahhahahahahahaa ;-)
