Yeah its got fibreglass fibres in it.
Hi every one, i have been reading all the thread and im happy to see you having good results!!.
i know you already covered the EGT gauges topic, i fell in love with McNally but it goes over the budget i was contemplating
Hope you guys could tell me if this one i find on eBay will be relyable, i like what it says on the description.
Thank you for sharing your work
Attachment 71083Attachment 71084Attachment 71083Attachment 71084
Sorry for posting twice de images, i´m also goning to do some exhaust work as i like what i have read here :D
Since I finally found where to fix the turbo for my SD33T, and im planning to change its original position and move it a little to the top so i can do easier the piping for a FM IC. Any thoughts on this?
Got my boost gauge today and the dawse kit from @mudski yesterday.
Got a peak boost of 17.6 yesterday taking off from a dead stop up a hill on the dirt. Boost is sitting on 10-12 at 100kmh, down from 13-13 pre zorst install.
Thats with the kit installed yeah? If so, I'd probably wind in the needle valve just a touch to get the 100k boost at around 12, and a little higher. The spool up on the turbo will increase a little too. But. You may not need to touch the needle valve though, if you think its fine. When you get the EGT gauge in, have a play around with the needle valve and you should see a difference in EGT's at 100k's with different adjustments.
Go easy if your going to use an exhaust wrap especially on a 4x4,
you'll find it will rust your pipes very quickly, if subjected to water.
Even race car and nascars dont use it for that reason
