Hi can anyone please tell me were the fuel pump is on a RD2.8t engine
thanks bob
thanks bob
look hard and you will find , but dont let it smack you in the head when you look around the motor
Up until a couple of weeks ago I had an MQ with a SD33T I know where the fuel pump is on that right in front and below the injector pump. I am new to the RD2.8T, the fuel line goes straight into the injector pump, I don't have a manual for this motor yet. So if it makes you feel good to belittle people who don't have as much knowledge as you seem go right a head.
Bob
Hey bob if its a GQ it is like a syfon feed system the only pump is the primer pump on the fuel filter housing.
The later GU electric injection model sory I'm not sure if they have a pump in the tank or just use the same as GQ.
Hope this helps or some 1 with a GU 2.8 may be able to help
Cheers TonyD
Thanks Tony it is a GQ and that explains why I can't find it.
Regards Bob
it's next to the thingimabob
um, I'm not being nasty, just silly, I would say the same thing if you were standing next to me and we were both looking for it
I have the manual, there is the primer pump and the injector pump on the GU as well.
