very annoying fuel filter on GU
my 08 3ltr crd has a very annoying fuel filter, the warning light came on one day so i had a look at how to drain the filter... well what a stupid design this is, the side that the drain pipe is on you cant get your had to due to many pipes in the way and yet if i could turn the filter 180 degrees around i can easily access the drain tap,,,, in the end i undid the bracket holding the entire assembly so i could lift it to get to the tap....
NOW... i would like to know..
can the filter be replaced by an after market one or should i put a water trap filter in before the factory filter???
putting a pre filter in causes another problem,, where to put it???
so please any help would be great, thank you
