repair to GQ clock
Thought someone might find this useful.
The dash clock in my GQ was totally dead. The plug in the back had the correct voltages on them, so the next most common suspect was 'dry joints' on the circuit board. Re-touching all the solder connections with my iron and a tiny bit more solder fixed everything and took about 5 minutes.
What happened was:
metal expands and contracts with temperature. car is 14 years old, so each solder joint has been flexed over 5000 times by the daily heat and cool down cycle, and metal fractures if you do this enough.
the result looks something like this:
http://www.nissanpatrol.com.au/forum.../2012/02/1.jpg
happy hunting
Thanks for that. I think most people resign themselves to the fact that the clocks just "stop working" lol. Mine is intermittent at the moment so I'd say thats probably the problem. I will try your solution:-)
Done this to a few over the years and it fixed every one of them.
I'll be doing this on Monday also ... thanks mate!!
yes done this also on my sons gq
Steve.
I shall be doing this tonight, mine has a mind of it's own.
Doing it now... Just saying to bring this thread back to the top for others that might need it... :)
