Will the crystal headlights and corner light from the later model GU bolt-on to my Gu series 1 or will it need some kind of modification??
I believe a series 1, 2 & 3 will fit but be careful, generally little changes in the models will be made to the headlights?? Check before you buy mate. Ring Nissan and ask them to check the part number for a series 1 2 and 3 headlight, if they are the same you have your answer.
looks to be the same but thought to ask in the forums if anyone has done the swap previously so i can be sure about it before i buy.
no one did this swap??
We are about to just bought the series three lights as they are the better ones but should just swap straight over will next weeked when we do the swap
Great!! please let me know how u go about doing it! if its straight swap i might wana get mine done as well including the rear tail lamps. Cheers
I've been wondering this for a while now, just seem to have found the answer:
Look forward to your pictures and confirmation
Awesome! Thanks for the link Beddu! so i will go ahead with the swap! but i noticed in the above link the side indicators had some water vapours inside.....non-genuine lights issue i guess
Straight swap mate no problems
Well, to confirm, they fit:
http://i6.photobucket.com/albums/y22...h_8db6d718.jpg
Ish.
http://i6.photobucket.com/albums/y22...h_7f78db75.jpg http://i6.photobucket.com/albums/y22...h_79b73532.jpg
And now protecting the investment.
http://i6.photobucket.com/albums/y22...h_6ed9af46.jpg
Need to be aligned though, as one headlight is currently doubling as a Airplane spotlight. This is what they replaced.
http://i6.photobucket.com/albums/y22...h_093a49b5.jpg
Also, hi, I'm new :]
