gday is there a way to adjust the rear barn doors to stop them rattling. The catch seems 2 have a lot of freeplay, it moves a couple mm. If i cant adjust them are the catches on a GQ the same
cheers
cheers
there should be a couple of loops on the body that you can adjust, one at the top and one at the bottom of the rear entry. Just loosen off the bolts a touch and adjust the hoops, takes a little bit of fiddling around with though.
ok cheers will give it a go
Im having the same issue. I will also try this fix and let you guys know how we go.
How'd it all go?
