I require a new radiator for the rig GU PATROL 4.5l PETROL automatic
could i have some advice aluminum or standard
cheers
cheers
Hi mate, this thread below gives some more info on the aluminium ones...
http://www.nissanpatrol.com.au/forum...inium-radiator
Thanks AB would the coolant situation be the same for the 4.5l petrol
Thanks PATCH I like the explanation I understand the importance of coolant I was referring to the other post/thred
Where
YNOT SAID Interesting dilema, do you use the coolant Nissan recommend to protect their engines or the coolant the radiator manufacture recommends for their radiator? You should be safe to use either. If your engine is a TD42 I would probably use the GM coolant to protect your radiator warranty, TD42's are pretty tough. Your choice.
Tony
thanks again Patch
