Is the patrol steering box like most steering boxes were you back off the lock nut then tighten down the adjuster to take out a bit of the play? The adjuster i speak of is on the plate near the front of the box where the bleed nipple is. Also is this nipple for when you drain the power steer fluid to get the air out instead of jacking the front end and going lock to lock?
