GQ elictrical Problems
Hi all, a while ago I posted I had trouble with my wiring, Weeeellllll,, It was a wire that had rubbed thru and was shorting when ever you hit a bump, IT was hiding under the battery holder, if any one has this type of problem, look there, 41500 DOLLARS LATER 4 ELECTRICIANS racv AND A MECHANIC FOUND IT did some other work as well and 900 dollars later , good as new,
Thanks for sharing the outcome/solution mate!! Glad you sorted it - even if it did take a cast of thousands to go through it!!
