Y61 TB45E - GN Relay Coil Feed Missing, Starts When Relay Is Jumped
Vehicle:
1999 Nissan Patrol Y61 TB45E petrol
LHD GCC/Dubai import
Problem:
The vehicle will not start normally.
It starts and runs perfectly if I manually power the GN relay output circuit.
What I have confirmed so far:
Interior fuse box has been replaced with another unit.
Relay #2 (GN relay) is good.
Relay #3 (AC relay) operates normally.
GN relay contact feed has battery voltage.
GN relay ground is good.
Manually feeding GN relay coil causes relay to click.
Jumping GN relay contact feed to output powers the METER circuit and the vehicle starts and runs normally.
Relay #2 measurements:
Key ON:
A = 0V
B = 0V
C = 12V
D = 0.21V
Key OFF resistance:
A = OL
B = 0.05Ω to ground
C = OL
D = 0.36Ω
This indicates:
Relay coil ground exists.
Relay coil power is missing.
Relay itself works.
Additional findings:
Instrument cluster was removed because it blows the METER fuse when connected.
Rear wiper connector was found melted.
Ignition switch connector has multiple ON outputs present:
Blue = 12V
White/Red = 12V
Yellow/Black = 12V
Black/White = 12V
There are also aftermarket yellow crimp connectors/splices in the ignition harness under the steering column.
My question:
Has anyone seen a Y61 where the GN relay coil feed disappears between the ignition switch and fuse box?
Does anyone know:
What feeds GN relay coil terminal A?
Which connector and wire color feed GN relay pin A at the back of the fuse box?
Any known SMJ, immobilizer, alarm, or GCC-specific modules that interrupt this circuit?
At this point the truck starts if GN relay output is manually powered, so I am trying to locate the missing trigger feed to the GN relay coil.
