WTF is happening with my reversing lights?
I have not junked with this circuit. I found today that when I de-isolated the earth circuit to the battery the reverse lights illuminated and stayed on with car running, could only extinguish them by again isolating the earth switch on the main battery.
First thing I thought was a faulty reverse switch, maybe sticking or fused shut? I had a look in the manual and it appears to be n an awkward spot, yet the Gregory manual suggests it's a 15-30 minute job to swap it out - on anyone else's car maybe but not mine. First thing I want to access is the plug and loom to disconnect and see if that is the activated circuit or something else. Has anyone here accessed the reverse switch on a TD42 manual box and how did you do it, from nderneath bearing I am hunting the wiring loom plug first or from inside the car via the gear stick access?
Also what else should I be investigating.
