8 Attachment(s)
Tangodoun's Drawer Build
Hey. Here's my first try at drawers for my GU patrol. I looked into a drifta build but decided to go DIY when I saw the quote. My goal was not particularly to do it as cheap as possible but to create what I wanted significantly cheaper than buying it. It came to half the cost of the drifta quote which I'm super happy with and I now have the worlds cheapest tracksaw and router for future projects. Of course the other cost is in the time it took to build which came to 9 days spread out but it's a fun project.
The end result is mostly inspired by the drifta wagon #2 build.
The left drawer is on teflon slides. I would have done the same with the right but got gifted an msa drawer that I had to make work with a plywood housing. That ended up being the most challenging part of the build and it wouldn't have worked without a router. I also recarpeted the front of the drawer to be an exact match to the rest of the carpet. There's a battery sized storage box at the back left and I found a neat fridge slide with a chopping board extension. The hutch is removable and I cut it to slot into the base and also have a few bungees loops for extra security.
Pretty much all of the material was cheaper somewhere else than Bunnings. A local fabrication shop did the angle treadplate up for the price of a six pack. For the carpet I went to a local motor trimmer and they also answered questions about the glueing process. I ended up using almost all of 3 sheets x 2400mmx1200mmx12mm construction ply and stand by the thickness choice.
Attachment 88973
Attachment 88976Attachment 88977Attachment 88978Attachment 88979Attachment 88980Attachment 88975Attachment 88974
The whole thing is mounted on the sides with brackets I welded up at work. They use mainly the third row seat boltholes and also funtion as the real structural supports for the wings.
The build uses heaps of t nuts to allow repeat disassembly/assembly and extra space for drawers. I was advised that a tracksaw was essential for accuracy and when i couldn't hire one, found a cheap one at sydney tools that i'd highly recommend.
The recessed wiring is for the led striplighting in the MSA drawer.
Wow, top job. The final product looks great. It's clear that there has been a lot of care and precision put into this. Well done!
Looks brilliant, high quality, just like a bought one. Also, totally custom to meet your requirements.
