TD42Ti engine on a cradle - some questions needed.
Hello all,
I've taken my TD42Ti out of my ute and I built a cradle for it with the gearbox attached to it.
TPS has been removed when I upgraded to 12mm pump
I want to be able to start it and turn it off.
I still have the engine wiring loom but not the rest of loom such as fusebox etc.
I have Carter lift pump with hose into jerry can hooked to the fuel primer.
I just need to setup switch for the carter lift pump to turn on/off - I can sort that
Starting the engine shouldn't be an issue but any advice would be greatly appreicated. I'd like to setup a switch to turn it on.
And a way to turn the motor off.
I am doing some benchmarking and doing some work on the TD42Ti over the next few weeks and would like to run it every now and then.
So any ideas?
Thank you in advance
Bree
