Is there a calibration/learning procedure after replacing the accelerator pedal assembly on a ZD30CRD?
I couldn’t find anything both on the web and this forum that is specific to the CRD
No calibration needed on the ZD30CRD after replacing the accelerator pedal. Just plug it in, clear any fault codes if they appear, and drive. If problems show up, check wiring or sensor fit, usually it’s an install issue, not a missing reset.
