8 Attachment(s)
Engine mount help needed - GQ TD42 front end vibrates like crazy
G'day everyone.
There is something bothering me for some time already which is that my GQ TD42 front end vibrates like crazy when at idle, much worse if it is cold off-course. So much that you can see the front bumper vibrating and if you hold it tight even the sound changes.
Engine mounts were changed after engine rebuilt, some 5 years ago, but that also represents only 2.000 Km ago. Upon inspection, the engine mount (injection pump side/Aussy driver side) has a bend on the lower steel plate that makes it closer to the upper steel plate, and it was contacting. Looking carefully it also reveals that the engine mount upper steel plate is a little bit offset to the rear of the engine.
Attachment 88713 Attachment 88712
I had saved my old ones for an emergency, so I decided to compare. Alone, the old one seems to have a much bigger gap on that section of the upper and lower plates, so I decided to replace the new one with the old one to test.
Attachment 88714
But out of the vehicle, both seemed to have the same gap. The older one only didn't have rubber in that section, making it look like it had a wider gap, but no.
Attachment 88715
New one is definitely offset to the rear of the engine now, compared with the old one.
Attachment 88716 Attachment 88717
Attachment 88718
I have then installed the old one in the engine bay and with the weight of the engine that part of the gap also rests one onto the other and the front end vibrates the same.
This car had a front collision at some point in its life and the front panels alignment was a bit rough, so my friend that is a panel beater had it straightened up a little bit for the panels to come more aligned. This was done with the engine in place, and I think this could have caused misalignments between the two engine mount brackets.
I am thinking of removing the engine mount brackets and welding them back with a better alignment to see if that helps. This would be a PITA cause the engine would have to come out. But I am still unsure about that bent part of the engine mount touching the lower part, since it does it with just the weight of the engine. I have even bought an engine mount for an local 80's truck that has parts easy to find here and an similarly heavy engine to compare, cause if I am to go the engine mount bracket removal route, I might as well change it to an easier to replace part, but the rubber on the Patrol one seemed so much softer then this test unit. And since I am trying to get rid of vibrations, the softer it gets, the better, I believe.
Attachment 88719
Any thoughts? Does the engine mounts on your TD42s have this little to no gap on that bent plate? This is a 4-hole engine mount type by the way.
