Gq not selecting 3rd or 4th gear
Hi all, just wondering if anyone has got any suggestions or knows the likely problem to what I have.
So currently I've got a 1992 gq tb42efi patrol auto, and It goes into 1st and 2nd perfect, I have just had an auto electrician check the ecu and tcm which they have conducted a full continuity test and have not found anything wrong with any of the wires, it been looked at by auto mechanic which have checked the mechanical side of the auto even putting it into lymph mode and thats when the transmission went into all the gears. They found nothing mechanical that is causing the issue.
What does anyone suggest I should do next?
Thanks for your help in advance
