Broken drive dowel in top cam gear ZD30
Hi ,it seems that the bolt holding timing chain gear onto the cam gear became loose and the dowel that drives the cam gear broke [ hence my other post on head removal ]
There was a little damage done to the timing sproket but thats included in a timing chain kit.
There does not appear to be any damage to the cam gear, as to the hole that receives the dowel.
Looked on Ebay and a 4mm hardened dowel is $6 , its longer than needed but I will just cut it back to length, being carefull not to get it too hot.
Has anyone done this before as i believe you have to buy the gear and dowel together from Nissan.
10 min. later I have just rung a large Nissan dealer [Barossa Valley ], says the part is not listed.
