10 Attachment(s)
VK56 starter motor changeout
Starter motor changeout
wasn't going to bother posting about it as it's fairly straight forward, but the concept of a starter motor in the valley can be daunting so here's what did
Parts
Starter motor $395 from patrolapart
Manifold O-rings $22 each (8 need Also patrolapart)
Some tape to cover intake ports
intake manifold removal
- engine cover off - 4 bolts
-undo half a dozen hose clamps and remove hoses few electrical plugs here n there attached to intake manifold and piping
-undo intake pipe clamp and unclip from airbox then remove
- undo 10 bolts holding intake manifold to block
- undo sensor plug from back of intake manifold, also undo bolt securing pipes to back passenger side
- gently remove manifold , it's only plastic so fairly light to remove
Starter itself
-remove battery terminal from battery to prevent any shorting from removing starter lead
-remove starter lead from starter motor
-undo clip for solenoid actuator wire, (tucked up passenger side rear) then disconnect plug
- undo small busbar to starter and rotate to allow access to Passenger side starter motor bolt
- undo both starter motor bolts
- remove starter
then repeat in reverse order to install new one..
Points to note and tips
Manifold bolts were hard to get my fingers too, use a magnet on the side of a socket to help retrieve them if you've got big goofy hands like me
The starter bolts were tight!, in a prick of a spot, and close to the casting so I couldn't fit my ratchet ring spanners around them. I ended up using a standard ring spanner that gave me a slight angle towards me, and threw a pipe on the spanner to get them to break, came out fairly free after that
New orings, I dabbed a touch of grease into the oring seats, just to keep them located when putting the manifold back in
Make sure you get all the manifold bolts in first before starting to tighten in. Basic mechanics I guess, but the back bolts are a bit of a prick to get too, use the others to line up the holes, then do the back ones as they should be fairly well located by then
Double check ALL hoses and plugs.. I went over it and still missed on that went onto the back of the intake pipe.. luckily spotted it before putting the cover back on
Siiiimples...
Yup... still drew blood on my hands... lol
