Tail Lights / Parking Lights / Dash Lights all blown at same time (2009 GU ZD30 DI)
So I've been trying to resolve this for far too long now. All the lights on the tail light circuit (Tail Lights / Parking Lights / Dash Lights) have all blown at the same time. I have replaced all the bulbs as well as the fuse (not blown?) and still can't get the lights back on.
It's possible the wrong fuse was in when they blew (15A instead of 10A) as while initially troubleshooting for the dash lights out I remember discovering an incorrect fuse. This was however before I realised all those lights were on the same circuit so I'm not sure if it was the tail light fuse or not.
All the threads I have found suggest the combination switch is the issue however, as far as I can tell, I don't believe it is. I have removed it and checked the circuit for continuity. Checking the circuit from before the switch component to the output shows the switch registers open and closed.
I have traced as much of the wiring as I can and cannot find any rubbing or loose connections.
All other lights (headlights, indicators, brake lights) work however it should be noted both my headlights blew around a similar time.
I'm out of ideas and am restricted to day driving so any help is greatly appreciated.
