Hi all
Just a small question, does anyone know what the black plastic disc that the PCV line runs through is.
Its bolted to the top of the tappet cover at the back ? Its on a GQ 2.8 turbo
Steve
Hi all
Steve
Someone will surely be along with an answer for you soon mate, sorry that I cannot help.
Steve, if the black plastic disk is something like this, then it is the PCV valve, which controls the flow of gases from the crankcase of the motor. If you pull it off you will find that there is a valve inside it, and you can blow through it one way, and can't suck back the opposite way. Helps stop the buildup of exhaust gases in the engine.
This one is off my GU 2.8 so is probably similar if not the same as yours.
http://www.myswag.org/gallery/d/1304...+VALVE+003.jpg
