Hi there, can anyone tell me how to get to the drivers side window switches? The toggle switch for the left rear seems to be faulty. Thanks in advance.
Hi mate. GQ or GU?
It's a G.U. 1998
You might need to unscrew the arm rest and slide it backwards to take the top off. There is a screw in the bottom of the grab
Thanks mate, i'll give it a go.
Ok, just had a look. I undid the screw but it would not move. So i tried to pull up the pad that you rest your elbow on, it came off. then the plastic moulding that houses the switch lifted out easily. So if anyone else needs to do this, that's how. Easy. Thanks mudrunner you put me on the right track.
just incase someone else has a faulty switch like i did, before you buy another one try a spray of ''servisol'' electrical clean and lube. Avaliable from jcar.
file ///sdcard/
