Rust in cool housing
Hey guys, just heads up if u already don't know. Make sure you check the top of your coil housing after Being at the beach or playing in the mud. I have a gu and the front area above the coils has a plate with 2 screws holding down a cover plate above the coil. Make sure you un bolt this and make sure it's clean underneath as I have just found out with rust in my drivers side. Very annoying. Hope this might prevent some of you's getting hidden rust..
Thanks for the heads up on that. Could you post a photo to make it easier for members to find the spot you are referring to please.
Tony
Will to tomorrow mate, it's right above our front coils, if u look at te coils and on top is a flat roun area with two screws, un bolt them and underneath is a hollow area where mud and sand builds up, I'll post a photo tomorrow of my unfortunate find of rust :-(
2 Attachment(s)
rust in coil housing
heres why you should check the front of your coil housing
