Hi all, thanks for the add. I have a 93 Coil cab Patrol with a dealer fitter turbo and owned since new with 135K on the clock and have a bit of a query with the oil pressure. It seems to be running very low on the factory gauge at Idle but quickly sits just under 4 kg/cm2 with a few revs. By low I mean a needle width above zero at operating temp but nearly 3 - 4 cold start up, not really sure how long its been like this as its not driven very much but have had some fluctuating readings from the temp gauge reading low over the years as well. First time I have noticed it that low so thinking its a new problem. Haven't put a remote pressure gauge on it to check yet but just wanted to get some thoughts as I read somewhere they only have like 11psi at idle anyway which is probably below the first mark on the gauge.
Cheers Phil.
