1 Attachment(s)
Hi there... now to dl that unoffical patrol manual
Picked up the 94GQ third hand about 17 years ago.
Engine was cooked a few years back and replaced with another TD42 adding a DTS Turbo kit hooked into a 3" exhaust, it came with some yellow chalk saying good and as it turns out a modified fuel pump and a hole in the sump ready for the turbo.
Few gremlins at the moment with starting turn over speed being intermittent leading to some long start times so I am looking at taking out the starter for a clean and to look at the bushes.
New air box that was installed with the turbo has rubbed through the AC pipe so things can get a bit sweaty in the cab at the moment.
Planing to install a DIY snorkel, adjust the rear brake balance and hopefully install the front mount intercooler before to long.
Recently blew oil into the chassis with a air pressure wash gun to slow down the rust.
Just installed the GU wheel nut upgrade as the front right bearing has come lose a few times and so far so good.
Shame that all this bush behind Sussex inlet has probably just been wiped out by the fires.
Attachment 79986
