Hi all, just did a full rebuild ne money spared but now the car is not starting, please help now desperate to put the car on fire?:?
Could be as simple as a crossed wire or a missing fuse. Is the timing 180 degrees out?. Are you dead sure the timing belt is on the right tooth. Who made the wiring loom? Did you splice into the existing wires or get it done professionally?
Also, try to bleed fuel pipes the air between the pump and nozzle can fall the engine start.
