Idle problem
Fellas I just finished the head gasket replacement on my GQ TB42e and find my idle is too high at 1100
rpm when warm. I've done all the normal checks made sure the cable was a bit slack with no pedal but still no change. Prior to the headgasket blowing it would idle at 750ish rpm. Any help would be appreciated.
Pete
As it was fine before you had it all apart,could be a vacume leak from a hose not being connected
Thanks Dean. forgot 1 vac hose :( All good now.
Good to hear mate,it's a usual,easy to make mistake
3 cheers for @Deano2506 hip hip horay, hip hip horay, hip hip horay
Reckon 90% of problems are either vacuum hoses or earth straps lol lol
