I may be interested in swapping VS commodore ute for MK patrol wagon
What I have on offer:
1996 VS Commodore ute V6 Auto
Clean Straight Body
Motor uses water cant find leak so suspect welsh plug. Has New radiator that was only used with coolant and on road for 3 months.
New Fuel pump and filter obviously. New Crank angle sensor.
Could do with some new front end parts, as (I think the left) a front tyre is wear out on inside edge.
Wheels are 17" VE mags with 2 good legal tyres.
If you want to make a showy ute, the plastic body trims will have to be replaced otherwise they are ok as work ute.
Bonnet and roof are flat black needing painting, and has some paint patches that were on it when I purchased the car.
It will need a battery, I can jump start the one in the car.
I was using it until I got my rodeo XL work body ute.
If it doesn't go I will do it up.
Ultimately what Im looking for, is a MK wagon, SDT33 5spd running. Don't care if wagon is rusty, as I want to put Ute cab on it, and a long tray.
Looking for a swap deal, I know its a long shot, but if you don't ask, you cant receive.
