How much advance is too much --- like 20 Degrees?
Silly questions, but i jest checked the timing on my TB42S and found the timing set at 20 degrees.....it is supposed to be 9-11 (lets call it 10).
It has been this way for a few 1000 km, since we purchased it last year. Only picked up a timing light today as I can't find the box of old tuning gear (went diesel for 15 years).
Is it likely to have damaged anything? Yesterday morning it had a hell of knock on start up, and it is gone today....going to check compression and oil pressure with a real gauge tomorrow (or perhaps tonight).
Also, it is only showing 22 degrees dwell, and it should be almost double that, but then again it does have a electronic ignition unit installed - I will check it was done properly though considering the timing debarkle.
Greg
Are you on LPG? If so, 20 degrees is not uncommon. 230k isn’t much on these engines either.
I’ve just put rings through an engine that had done 400K - and it didn’t need a bore. I gave it a hone and put standard size rings in - its running beautifully.
Sent from my iPad using Tapatalk Pro
