Oils and filters list
Ok this might be here some were?
ZD30 GU 3
Fuel catrigde p#1640359EOA (Nissan) $48.73 x1
Oil filter p#152092w200 (Nissan) $28.83 x 1
Air filter p# (Nissan) $ x 1
Motor Oil p# Delo 400 Caltex $84.21 8.3 Manual said 6.4 L
Power steer fluid p# Type DEXRONTMIII castrol ?L
Brake fluid p# DOT3 or DOT4 Castrol ??L
Transfer fluid p# ?L Differential carrier gear oil (without limited slip)FRONT p#
Differential carrier gear oil (with limited slip) REAR p#
Manual transmission P# 5.1 L
Cooling system (with reservoir tank) p# 11.8 Anti-freeze coolant (Ethylene glycol base) With front heater p#
Wheel Bearings Grease P#
Tail shaft Grease p#
Have I missed any as my gu3 has 200,000ks up and it for 6 months and wont to do the lot so I know were it at then I know when to change it next
Thanks for any help:D:smiley_thumbs_up:
Ok I found this on that other Form http://www.datateck.com.au/lube/castr_au/default.asp But it is Castrol
Thanks Cossy, just putting together a list of things...on top of the mods to do, your list has just made it simple for me. Aiming to treat this patrol really well. Not touching anything though until the warranty ends! 3 months, plenty to learn in that time. Exhausts, can someone direct me to a good thread on an upgrade exhaust for the GU3.
Geoff
Thanks for the links, remove the confusion of choosing the right lube for my GU
