dpetersen
Gday all!
As some of you may know iv recently purchased a 2006 4.2tdi wagon. Completely stock, only a set of rear draws. It also has bubble dash. 217000ks.
IMO I got it for a pretty decent price.
Now I pick the car up from Melbourne in a month or so and will be driving it back here to Alice Springs. I have access to a hoist and workshop here but I am moving back to Melbourne in the middle of the year so I am planning to do a lot of work here while I have the workshop. I have budgeted about 4-5k on what I would like to do.
I have a lot of questions and am hoping for your help.
First of all, apologies for the long winded post.
I currently have a gu3 zd wagon, have owned for about three years, so there’s a few bits and pieces I’ll be pulling off that before I sell it.
Catch can - provent, will be removing from zd 30. Use it on the TD
Ecu talk - will be removing from zd30.Sell it
Egr block - cheap from eBay, thoughts?Leave it
Diff breathers - cheap from eBay, thoughts?leave them. Not expensive to buy
Window tint - tint professor melbourne, have budgeted $300.sounds a bit cheap
Snorkel - no idea. Aside from looks is stainless much better? Currently have Ironman on my zd30 with no complaints. No idea what to budget. bear in mine the custom snorkels that dont use a ram head and point back create a lot of induction noise. I have a Radius Fab snorkel but with a 4inch ram head. Budget for a custom snorkel around $700
Bullbar - I have a TJM T13 or 15 on mine at the moment and like it so I am thinking a TJM T13 for the new car. Estimating around $1700?
Exhaust - 3inch. Can pick one up from 4wd supacenter for around $700 but I have read good things about beaudessert aswell, I think I read they are around $1100? What are your thoughts? I cant really comment on the 4wd SC pipes, not much to go wrong but the only thing to look out for is the flanges where the pipes join together. Might be a weak spot. See what sort of warranty they have on their pipes too. I run a Redback branded system...
Dual battery system - currently have a red arc system in the zd and no complaints.I really only run my fridge from it. Can’t remember what it cost. Budgeting around $700 including battery.
Roof rack - currently have a steel full length tradies rack and love it. Would like the same. No idea where to go or budget.stick with what you know maybe on this....
Suspension - currently running a 2inch lift from Ironman with foam shocks and steering dampener. I think I paid around $1100. No complaints so wouldn’t mind the same or similar.if your happy with this then buy the same I guess. There is better out there, but more $$$
Drivers side wind deflector (full size as I am a smoker) - Nissan?
Servicing - pretty much always do it myself, oil, oil filter and fuel filter every 5000. What’s the deal with the two oil filters? Are they both the same part number? I usually use ryco filters, what are your thoughts? Are Nissan better? Much more expensive? 10.5 liters is what I have read the car takes. I have tried many different types in the zd and found Castrol gtx diesel 15w40 to be best. Would this be the same for the td? Ryco is fine, Genuine is also, same as Fleetguard. Your two filters should be the same, the earlier TD42 GU's used two different filters... The GTX Diesel would be fine. You could use RX Super, can be had in 20L tins and is cheaper this way.
Intercooler - are the tdi ones as crap as the zd’s and prone to leaking?Yes
Bubble dash - I did read a while ago that Nissan were helping in some way with this. What’s the story with it now? They arent any more. They are about $800 new to buy. Not sure on what it takes for the remove and refit though.
Again I’m very sorry for the long post! I’m excited to pick the car up and get strait into working on it!
I’d expect I’d be able to do nearly all the work myself. I don’t mind paying a little extra for quality but sometimes with 4wd parts I find you can end up paying a fair bit more just for the brand name. Example - I have had my thumper air compressor for nearly three years and can’t fault it, cost less then $100!! Hence why I am after your advise.
Thanks heaps, Daniel.
