Varex Technology
Varex Technology
VAREX mufflers combine both the design technology of the stock muffler and the performance muffler into one single compact unit. A sophisticated butterfly valve mechanism is implemented to redirect the exhaust gas flow and vary be-tween the two.
For higher sound level, the exhaust flows are directed through the opening path and produces maximum power with a robust sound level (or the “sports car note”) and near-zero resistance. Whilst for lower sound level, the exhaust flows are directed through the chambered path (similar design with the stock muffler), and produces minimum sound level that gives you the best in-car comfort.
Angle of the valve is also controllable, which can be adjusted to stop at any point between sports mode and silence mode. This gives you further freedom to set the optimal sound level according to your desired preference.
Varex Motor
http://i762.photobucket.com/albums/x...Force/Pic1.jpg
VAREX Motor and gear sets are located on the top of the muffler, they work as an integrated unit to drive the butterfly valve open and close.
The dimensions of the motor and gear box are typically manufactured to 4.5cm(H) x 10cm(W) x 20cm(L)
Varex™ can be controlled to suit your personal needs.
The Varex Remote controlled muffler
Street Mode
http://i762.photobucket.com/albums/x...rce/Post12.png
Setting your Varex muffler in 'Street mode' enables lower sound levels and maximum discretion, as exhaust gases are directed through a chambered path as would a 'stock' muffler
Race Mode
http://i762.photobucket.com/albums/x...e/Post13-1.png
For greater power output and sound level, exhaust gases are directed through the opening path and produce maximum power with a robust sound level (or the 'sports car' note) and near-zero resistance.
"Anywhere in between"
http://i762.photobucket.com/albums/x...rce/Post14.png
As the angle of the valve is infinitely adjustable, it can be adjusted to stop at any point between sports mode and silence mode. This gives you further freedom to set the optimal sound level according to your desired preference.
Below is a diagram which shows the basics of the Varex muffler kit:
http://i762.photobucket.com/albums/x...rce/Post15.png
Easy Installation, no hard-wiring required (in-car 12v socket included) for plug and play functionality
Durable construction with water resistant plugs
Dual mufflers control harness available
Stylish remote key pad (x2)
Varex Kit Contents
Complete Varex Muffler Kit includes:
Varex harness with water resistant
connector & power plug
Control Module
Remote Control Keypad
Varex Muffler of your choice
Muffler Band
Varex Control Kit
VK01
Water resistant plug (connected to
Varex Motor)
Power plug
Control module
VK02
Dual control kit. It shares the same components as VK01 except having two connecting Plugs for dual VAREX mufflers.
VK05
Automatic control kit which features an extra function that can adjust the volume automatically according to the pre-set RPM by users.
http://i762.photobucket.com/albums/x...rce/Post16.png
(*Graphics are for illustration purposes only, actual product may vary)
Varex video:
http://www.youtube.com/watch?v=pqbS6...embedded#at=81
Great for a streeter got mates with em good for when the laws around too
How many $$ I hear me and many asking....
Tim
what are you after ? let us know and i'll do the leg work .
