Fuel pump not turning on - help please
Hi all, this is related to my other post here, this post however is related specifically to the fuel pump issue rather than which fuel pump to use.
Auto 2000, GU, 4.5 litre on LPG with Petrol Sub-tank
The car went from working fine to not running on fuel. So I thought it was a the fuel pump.
So ok I have replaced the fuel pump, reconnected the fuel wiring and hoses and installed it all back into the car. I am still not getting any fuel flow and I can't hear the pump going. If I put power direct from a battery to the male blade ends on the top cover of the pump power plug the pump turns on fine. If I reconnect the power plug (two wires) back into the pump, it will not turn on. So I checked fuse and relay, fuse is ok and the relay seems fine. I then checked the power I am getting from the relay plug end and I am getting 12.4v, however when I check the power plug into the pump I am getting 11.6v. I understand there is resistance that can cause this to happen but it appears that the power it is getting may not be enough. I swapped over relays from other relays but still not getting the full 12v at the fuel pump plug wires. There has been nothing changed prior to the pump stopping to work.
My Fuel pump relays are located in the up to 2000 GU model under the glove box, not above the fuses under the driver side dash which is from 2000 models.
I am able to run on LPG fine, but it takes a little extra time to start.
I live rural and my closest 'suitable' mechanic to assist is 130kms away.
Has anyone got any ideas for me to try to resolve this issue
Greg
