Td42 alternator
Hi I have a 1988 td42 patrol and need to replace the alternator but can't find one that matches the original one do I have to buy one to suit that year and modify it to work or is there one that will match the original
Some advise on this would be great
Mudbug
You shouldn't have any probs getting the right one.
Have a look on ebay
Patrolapart should have one.
Any GQ TD42 alternator will be fine, even GU TD42 ones will fit and be fine, just make sure the vac pump is on the alternator as some GU's changed the pump to the LHS timing case rather than back of alternator.
Auto 8 on eBay have upgraded amp alternator with a good warranty but keep your receipt.
Thanks , all replies were good advise I was mainly concerned about the plug connections but after looking further with all your help I have a lot to choice from now I should be ok now
Mudbug
