Hi all,
Does anyone know the resistance of the main and sub tank fuel sensors on the GU Patrol?
Need to find out what the empty and full resistance readings are.
Kindest Regards
Rainsey
Sent from my iPad using Tapatalk HD
Hi all,
Kindest Regards
Rainsey
Apologies Rainsey mate, don't know :-( I'll do my best to find out/search for you here ASAP and swap you the info for your Manometer pressure stats forthcoming, lol :-)
I've had no luck sorry Rainsey mate :-( Can we make another deal please bro :-) ?
Ha ha, yeah I have been a slack SOB. I have the manometer sitting on my desk and I'm still thinking of the past discussions re what it will actually measure after all.
If I face the input directly forward it will measure the incoming air pressure but this will vary to speed and not be an accurate pressure measurement.
Side on, with air rushing past it I'm guessing it will create a Venturi effect and do the same as above but with a negative reading.
The missus is a way next week for a few days visiting the folks and staying in the will, I'll grab it out and see if I can get motivated again.
Rainsey
G'day mate the resistance values are aprox 6 ohms full, aprox 33 ohms half, and aprox 80 ohms empty, these are the same for the main and sub tank gauges.
The main tank is measured, between terminals 1 and 2 on the gauge connector and the sub tank is measured between terminals 1 and 3 on its connector.
Hope that helps, Paul
