Turtle_au
On the open road the biggest influence on economy is aerodynamics. Escecially on a wagon as you get a low pressure zone behind you which is trying to suck you back. Think of the turbulence behind a semi at speed. Anything that disturbs airflow (bullbars, roof racks etc) causes low pressure zones that will add drag. Even a lift will cause more drag under the vehicle. And its a square function -- if you double the speed the drag increases 4 times.
Thing to help. A wind deflector at front of roof rack, a tight cover over any load on the roof rack. Wind deflectors at the rear to direct some air across the back window to stop dust build up on the rear also reduce the drag by reducing the low pressure zone.
As GQtdauto said he gets better economy when towing, because the trailer (especially a box trailer or camper trailer will smooth out the turbulence.
Try an experiment, put your hand out the window at various speeds and you'll see how much drag each speed produces.
As a side note this is the reason the USA introduced 55mph speed limit during fuel crisis to try and reduce fuel consumption across the board.
Sent from my SM-T355Y using Tapatalk
