Turtle_au
get some longer bolts(about 25mm longer)for the bellhousing. Use about 4 of these when reinstalling gearbox, it makes lining up easier when there is still a 50mm gap between bellhousing and engine. Tighten these up lightly until you feel some resistance, rotate the gearbox output flange until the splines on the clutch engage ( the flange should stop moving when they lock in). Tighten the bolts up a little more. Fit the slave cylinder and operate the clutch. This will release the pressure plate and align the driven plate. The gearbox should then be able to pushed all the way home. Fit remaining bolts and replace longer bolts with originals.
