G'day all.
My car a GU3 that was for the first 10 years a ZD30 direct Injection Auto but at about 349,000 KM it had an un containable component failure.
Thats history now it has a TD42 Turbo driving a 5 speed manual since early 2014.
Since the engine swopp that was apparently fully rebuilt the car has had this odd problem on and off.
I don't really think we ever got this fully resolved but get to the point.
When I park the car on a hill up or down no difference.
When I start the car first thing I notice is I have no Vacuum boost for clutch or brakes.
Oil Pressure warning light stays on usually until I either get on more level ground or I shut the engine down and re start it.
Then all is good I drive off and the oil light goes off and normal vacuum assist is normal.
The car has been plagued with this problem on and off since April 2014.
The pressure switch was changed recently but still doing it.
At Christmas 2016 I had get the car Tilt trayed home from The Aldi car park in Gyimpie.
Now last week after doing some home shuffling of my camper at home.
I drove the car back up to the garage and guess what Oil pressure warning light is on solid now cant get rid of it.
This is a new pressure switch fitted in Dec 2016.
I had my doubts that the oil pressure switch was telling the truth so I got an oil Pressure gauge and fitted it in a T at the same location as the oil pressure sender device.
Now I'm quite sure that there is no oil pressure as the tube that goes to the new oil pressure guage has no oil in it, not a trace!
What have I done thus far?
Oil level is fine I have added more oil so I'm not suspecting the oil pick up, It was parked on level ground anyway at home and at Aldi when this fault occurred.
This week I have removed the oil cooler with the two oil filters.
When I took the oil cooler jaket off I found that the O ring and gasket were not where they should have been see the foto below...
Now I'm no Motor Mechanic but this look bad.
Not happy with the way this looks but a little surprised that the oil and coolant have been kept separated. Also given the poor state of the o rings and how far off center to where they should be,
This motor had a Full rebuild?
I've pulled the Cooler oil pressure relief valve out and looked at it and the other valve, System pressure regulator valve, I cant fault them clean and moving freely.
My next task is to pull the Oil Pump over pressure relief valve off and check it
When the engine runs I can hear oil running back into the sump. So I'm not at this point suspecting the oil pump.
I'm at a crossroads. once I gave pulled the last valve off to check it under the Turbo thats it!
Has anyone here got any other Ideas.??? Please Please..
I have put some more fotos up.
My findings so far are pointing to the oil Pump pressure relief valve. This is under the Turbo.
When I took it to the bench to remove the valve from the valve body it took several hard knock on the bench to get it out.
I found it was not moving freely and did not fall out under its own weight.
Its pitted dirty and looks to me like it was stuck, in what position? I don't know
I have cleaned it polished it and will re assemble and tset in the coming days.
I cant be sure until I put it all back together.
Attachment 70837
Attachment 70856Attachment 70857Attachment 70859Attachment 70858
Well I'm really quite stumped.
I have put it all back together with new oil filters.
Started the car still no oil pressure.
The oil light stays on and the oil pressure gauge reads zero.
I have tested the oil pressure gauge with air pressure so I'm sure I have a working set up..
So to be clear I have no oil Pressure. I'm pretty sure I'm not getting any oil even coming into the oil Cooler.
I had this all off cleaned it had it welded up because I damaged it.
Should be easy for me to prove as I have just put new filters on, So I'll remove them in the morning.
I fully expect to find no oil in them or very little.
Also I filled up the coolant only to find the thermostat housing gasket in such poor condition that it was leaking like the Trevy Fountain.
Another fault that should not be after a full rebuild.
Attachment 70926
Attachment 70927
This is the oil Pump relief valve housing
