Can't get indicators to work, or hazards. Flasher unit is OK, bulbs & wiring to the bulbs OK, fuses (both indicators & hazard) OK & have power leading to them.
Can I find a wiring diagram for this system including the indicator stalk?
you casn go and download the manual that suits your car mate,25 posts no longer needed,just make sure you've done an intro and registered ya email adress and you should be right.
What model Patrol?. Have the fuse been blowing previously?
Have you just replaced the radio or had the radio out?
Thanks guys. All now working with your help. Bad connections at the hazard switch.
ceers for the follow up,help when people research same problem and there is an answer,
