6 Attachment(s)
How to fit large battery, winch cables into crimp ends.
Have come up with a simple way to make this pita of a job quick & easy.
you know trying to jamb the larger cables into the the crimp ends is almost impossible without trimming strands off.
Note -using flared end type fittings is a must have as in pics
Trim the insulation off and the end will swell up making it hard to fit into terminal end.
with the insulation removed ea strand is now free to bend how ever it wants.
this cable is 0 gauge near thumb thick and a royal pain to work.
Attachment 70325
Now get 2 cable ties.
Attachment 70326.
Important---inner very tight, outer one tight enough.
The ties stiffen up the strands allowing you get the job done
Now fit the terminal onto the end as it will slide on over now much easier.
Attachment 70327
Start to turn 360 deg and push it on as you go.
twisting it left right doesn't work, it makes the strands bunch up and that's not wanted one little bit .
just keep twisting & pushing one way.
the looser outer tie will slide down as you work it till both ties are touching together.
Attachment 70328.
Now cut only the outer tie off leaving the inner one alone.
Attachment 70329.
Continue to work the end down to the next tie.
now cut last tie away and continue working end down till you hit insulation.
Attachment 70330.
Crimp and cover with heat shrink etc finished.
this way, start to finish I had each end snugged down no time at all ready for shrink tube.
A cheap hydraulic crimper off ebay pays for it's self easily in 1 winch job = 5 large cables =10 ends to crimp.
Hope this helps ya out of trouble.
Cheers.
