Ignition key barrel lock wont turn
I was in Whyalla on the weekend when the ignition key barrel lock stuck and I couldnt start the car. They key would would move in and out but I couldn't rotate it to start the car. I called the RAA and after an hour they showed up. The RAA guys sprayed some lubricant in first but it wouldnt turn. He than tapped the end of the barrel with a hammer but it was still stuck. He then took the plastic cowling off and started tapping the barrel with the hammer until it freed up.
He said that it was just a pin that was stuck, maybe from some dirt or lint on the key. He looked at my key and said it didnt look too worn and that maybe the barrel was a little worn. He suggested I get it replaced or disassembled and cleaned. The car has started without a problem since then but I now have this feeling that it will happen again.
In an older thread from 2014 mudski wrote: O.k I recently went through all this with my GU. I went and saw my locksmith, and he said the barrels on these cars don't wear out. The keys do...I got the code for the key and the locksmith cut new keys to the code and all's good.
(http://www.nissanpatrol.com.au/forum...rel-won-t-turn)
Before I call some lock smiths to get a quote I wanted to find out if this is a common problem or if its simply the keys. The door locks also feel a little notchy when I open and close them (DX so not remote locking). This is an ex Telstra car so I assume it was locked/unlocked many times each day.
