Rear Diff Occasional Grind
Ok, so, weird one. GQ LWB rb30 4.3 diffs on 35's.
I've only had this happen twice. Once when flexing in mud, and once when driving up a hill covered in ice.
Basically, every now and then in these extreme low grip situations, I'll get a grinding noise and then sudden drive from the rear.
I haven't dumped the oil. At a guess, I'd say that I'm lifting a wheel or there is insufficient traction for the LSD, and it's basically turning itself into a single pegger. When the lifted wheel drops back down, or I get a bit of traction, I get the grind which I think is perhaps the clutch packs in the LSD grabbing again?
Has anyone experienced this? Any thoughts? Diff/car has only done 130k kms, and normally LSD's fine (like I said it's only happened twice).
