what you need..
Bunnings..
30mm and 25mm box tubing.. Come in 1m lengths... Don't be alarmed with size its a snug fit..
20mm flat bar... .................... " ".....
Gal link chain..
eye hooks
Mud flaps are floor covering from Super cheap....
2 x 40mm bolts
1st
Cut 30mm box section to suit x 2.
Cut 25mm box @ 200mm x 2
http://i223.photobucket.com/albums/d...y/IMG_0413.jpg
http://i223.photobucket.com/albums/d...y/IMG_0414.jpg
1st pic, is the straight bar welded on. This will have the mud flap bolted to it.
2nd pic, I have the smaller box tube inside with 10mm left (reason 4 later) Drill a hole through both tube sections the same size as the bolt. put bolt through and slightly tightened. Then weld the nut to the tube. This make for your easy access and to undo.
http://i223.photobucket.com/albums/d...y/IMG_0415.jpg
Capped off end
http://i223.photobucket.com/albums/d...y/IMG_0418.jpg
http://i223.photobucket.com/albums/d...y/IMG_0416.jpg
Next setup up 10mm over hang end to chassi at your required hight and weld a tag.. adjust to your liking.
Then weld the 25mm section to the chassi (2nd)
See in this pic how it will slide over, with the already welded nut to the box tube it will make for easy removable of the mud flap by just undoing the bolt..
http://i223.photobucket.com/albums/d...y/IMG_0417.jpg
See in pic (4) of the bolt which lines straight up and bolts in..
Bolt on mud flap (in my case rubber floor mate)
Chain it up to what suit your needs..
http://i223.photobucket.com/albums/d...y/IMG_0420.jpg
Easy removal by undoing bolt and sliding out. slide to put back on and tighten bolt..
Cheers Jay
