Hi Guys,
I just discovered the my RB30 PATROL needs some attention with the brake plumbing system.
Apparently there's a leak between the master pump and the brake booster.
The oil is visible on the brake booster body behind the brake master pump, and has been slowly dripping down the booster outer body towards bottom end of the engine bay. It's not gushing oil out, but still bad enough to cause the brake warning light to come one on when I brake suddenly or take sharp bends.
I topped up the brake oil on the master pump for the time being.
What is the likely cause?
How should I approach on fixing the oil leak?
Thanx in advance for any advice, help, etc.
