Dimmer switch & pod gauges
hi all, after some auto lecky advice
i currently run an Autron EGT/Boost/Oil Press & Dual Volts/Amps gauges in a pod in my 2005 GU IV, it also has the enhanced lighting controller.
I was finding the night time light levels really annoying when travelling in the dark hours, so i managed to set them to a decent level at night. My main problem is that i use the lights during bad weather etc during the daytime which makes the guages unreadable when i turn the lights on.
Since i dont want to use the current dimming switch to dim gauges as well (due to other issues caused that i have read on forums), i was thinking of using another dimmer switch from the wreckers to control dimming of gauges.
The instructions for the Redarc GA-ELC (Autron) ehnaced lighting controller shows 2 yellow wires coming from it & going to globe in dimmer circuit
https://www.redarc.com.au/Content/Im...n%20Manual.pdf
is it a matter of attaching the 2 yellow wires to either side of the dimming switch or is there more to it? the switch has 3 posts coming out the back of it not sure which post is which
Help would be appreciated.
Nathan
