Hi guys what would you expect to pay
for the rear drive shaft uni joints
Around 50ea
Might want to give Neil a buzz at Roo Dog spares
http://stores.ebay.com.au/ROODOGS-4WD-SPARES
Give Roadrunner a call roofy. They're not far from you.
Going to town tomorrow PatrolApart just down the road from Janes kids and grand kiddies
usually get a good deal there
Advice before installing the uni's remove the caps and pump full of grease to remove all the air then put a bit of grease on the caps, then install. What can happen if you don't fill the uni's internal grease channel you can get a air lock, so when you goto regrease it one of the trunnion's will run dry.
A quick and easy way of removing a uni from the tail shaft is a 9" angle grinder and cut it out then you can easily push the caps out of the yokes.
